Relay switches
120,000 MILES • 3.0L • 6 CYL • TURBO • 2WD • AUTOMATIC
RIEGUY510
Would the relay switches cause a car to crank but not turn over?
Mar 12, 2019 at 3:57 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Is there a specific relay you are referring to? Among other relays, this car does have both a ignition relay, ECM relay, and an anti-theft relay. Any of these could be causing a no start.
Here is a link that shows how to test a relay:
Here are a few links you may find helpful:
________________
Also, here is a link that discusses the most common causes of a crank no start condition. I'm adding this because many things can cause the condition you described.
Let me know if any of this helps or if you have other questions.
Mar 15, 2019 at 1:12 PM
