Rattling sound when accelerating?
190,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
TOBYM
When I start the truck and accelerate slowly it sounds good but when I give it a little gas or have to pass someone it rattles out the exhaust. I've already made sure everything is tight and in good working order. I don't know if it could be my engine or something like my catalytic converter going bad.
Oct 26, 2022 at 10:27 AM
  • 110,248 POSTS
If it sounds like it is under the vehicle, it is likely either a loose heat shield on the exhaust or the internal portion of the catalytic converter is loose.
Try this. Take a rubber mallet and tap on the exhaust in different places to see if you can recreate the sound. If you have a helper, it will make it easier.
Let me know what you find. Also, here is a link you may find of interest in the interim:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
If it is loud enough for you to record, please do so and upload it for me to hear.
Oct 26, 2022 at 1:12 PM
TOBYM
I had the truck in park and revved the vehicle up to 3,000 RPMs and it never made the rattle sound. It only happens when I'm driving, and the RPMs hit around 2,000 to 2,500 RPMs.
Oct 27, 2022 at 9:42 AM
  • 110,248 POSTS
Were you able to check it using a rubber mallet as mentioned above? Also, could you record the sound and upload it for me to hear?
Oct 27, 2022 at 11:05 AM
TOBYM
I tapped with a mallet, and nothing rattled. I came to the conclusion that it's because there is no muffler on the truck and think it's just the way the engine/exhaust sounds.
Oct 28, 2022 at 10:11 AM
  • 110,248 POSTS
No muffler? It must be loud. LOL If anything changes or gets worse, let me know and I'll do my best to help you narrow things down.
Take care of yourself and please feel free to come back anytime in the future.
Oct 28, 2022 at 3:04 PM
