1997 Dodge Ram Catalytic Convertor
1997 DODGE RAM
125,000 MILES • V8 • 4WD • AUTOMATIC
XENEDRENE
I bought this truck 2 years ago and had to change the convertor. I put in a high flow. It has been a year since then and I am experiencing rough idling all the time, hesitation with acceleration and my check engine codes are P0300, P0303, P0304. (which are multiple misfires)
I probably will have to change my convertor again but why is it plugging off? The Dodge also came with a K&N air filter and I put new spark plugs in it when I bought it but that was 2 years ago now.
Sep 9, 2009 at 12:27 AM
RACEFAN966
  • 5,029 POSTS
Ok you are getting a multiple missfire the P0300 and then you are getting cylinder number 3 and 4 as missfires. Now I must ask does this truck have a mass air flow meter? If so get some mass air flow cleaner and clean it. I do not think it is a cat as you would have a huge power loss. I think that maybe the K&N filter has been over oiled and some got on the wire for the mass air flow unit. After you clean the sensor then clear the codes (this requires a scan tool) and let me know what you find. When you replaced the cat did you replace the rear O2 sensors? Get back to me with as much info you can and let me know how it goes.
Sep 9, 2009 at 3:08 AM
XENEDRENE
Where is your mass air flow sensor exactly? And no the rear O2 sensor was not replaced when I changed out the cat last time.
Sep 9, 2009 at 9:58 AM
RACEFAN966
  • 5,029 POSTS
OK your truck don't have a mass air flow meter I checked. So if you have a digital multi meter or a scan tool I would like to check the crankshaft position sensor. Here is a pic let me know if you have a meter or scanner so I tell you how to test it.
https://images.2carpros.com/forum/automotive_pictures/249564_483321_1.jpg
Sep 10, 2009 at 3:20 AM
XENEDRENE
No I don't have a digital multi meter. I do have an OBD.
Sep 10, 2009 at 5:08 AM
RACEFAN966
  • 5,029 POSTS
Can you scanner do a live scan? If not then you will need an inexpensive digital multi meter so we can run a couple of tests. Let me know what you scanner can do.
Sep 11, 2009 at 3:17 AM
XENEDRENE
Yes it can but I have no idea what it's telling me.
Sep 11, 2009 at 3:39 AM
RACEFAN966
  • 5,029 POSTS
Ok first I would like you to check the TPS with the scanner. It will give you a voltage reading. Key on engine off you should get .2 volts or more, then slowly raise the throttle and it should steadily increase to 4.5 to 5 volts, with no glitches or drops as you open the throttle. Lets start with that and then we will check the map and cranksensor next. Let me know what you find.
Sep 12, 2009 at 1:43 AM
