Radio/clock do not turn on when key is on engine off
202,852 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MAYCO123
So a few weeks ago my radio stopped working the clock stopped working long before i checked the dome and accessories fuse seems okay. checked connectors to see if radio had power it did. so now i am stuck what would i do now?
Jan 10, 2017 at 6:39 AM
STEVE W.
  • 15,420 POSTS
Check/replace the two fuses (have had some that looked god but were bad). If they are okay I would suspect internal failure of the radio. especially as you lost the clock before.
Jan 10, 2017 at 8:38 AM
