On each side of the radiator at top tank are 2- 10 mm head machine screws holding the "condensor coil" for the A/c.
Am I correct that these 2 connections are not ALL that is holding the coil, just added as supports from the radiator?
Once I remove the top hose, bottom hose and remove the 2 shrouds then I will gain access to the auto trans hose connections, and removal of the screws atop the tank for the "Coil as previously mentioned I will be able to pull the radiator up and out. Another words no screws at the bottom out of sight connect to the radiator to the coil.
Please advise
Thank you
Was this helpful?
Friday, February 12th, 2021 AT 9:53 AM
(Merged)
