2003 Hyundai Elantra water pump repair
MATTBEN8
  • 2003 HYUNDAI ELANTRA
  • 4 CYL
  • 4WD
  • 60,000 MILES
I just had the water pump repaired and the labor was $381. Does this seem excessive? I am curious as to the average hourly rate for this repair? Thank you
Friday, April 18th, 2008 AT 7:11 PM
MASTERTECHTIM
  • 4,750 POSTS
3 hours. You need to remove the timing belt to access the water pump. Its fairly complicated. 400dollars for this job is common
Friday, April 18th, 2008 AT 8:19 PM
BMRFIXIT
  • 19,053 POSTS
Its just about right
lot of work
about 3.5 hr and about $90 for the pump
plus coolant
Friday, April 18th, 2008 AT 8:28 PM
