Overheating issues
CBUCHAN3
  • 1998 SUBARU LEGACY
  • 6 CYL
  • AWD
  • 230,000 MILES
I have a subaru legacy outback that is now overheating constantly and I think it continues to lose water. I don't drive my car on the freeway anymore. I try to keep it under 55mph and it seems to overheat less. I have no idea what it could be. I took it to a radiator mechanic and they replaced the plastic parts where the hoses are attached because those pieces were cracked. I also put a new radiator hose on because that blew. Excessive pressure still builds up in the hose and you can actually hear the water boiling. The mechanic didn't think it was the thermostat because when the radiator is filled, the car doesn't overheat. What would cause the car to lose water? The radiator doesn't leak and the inside of the radiator is clean. I get it flushed at least once every two years. I just drove to work this morning and the fluid was just pouring out of the overflow by the time I actually made it to the office.
Wednesday, March 13th, 2019 AT 5:53 PM (Merged)
Try replacing the thermostat-and check if the water pump is doing its and fan coming On on time if okay try bleeding the cooling system-don't work get it block and pressure tested-
DEANPOLK
  • 2000 SUBARU LEGACY
  • 4 CYL
  • AWD
  • 109,000 MILES
Engine overheats almost immediately after starting. Radiator is full. Was told it might be a blown head gasket. How do I diagnose the problem?
Thank you
CARADIODOC
  • 33,917 POSTS
If you see bubbling in the coolant reservoir when the engine is cold, suspect the head gasket. Also, there won't be any steam and the coolant and hoses will still be cold.
Your mechanic will use a special tool to check for combustion gases leaking from the cylinders into the cooling system. It is a glass cylinder with two chambers partially filled with a dark blue liquid. Air is drawn through the fluid from the radiator. If combustion gases are present, the fluid will turn bright yellow. That will be conclusive of a leaking head gasket.
Caradiodoc
BOCARD80
  • 1995 SUBARU LEGACY
  • 252,000 MILES
I have a 1995 subaru legacy with a overheating issue, radiator was flushed and burped and still overheats after 10 mins of driving it makes no sense. Mechanics are not sure whats going on or never worked on a subaru before, coolant has no bubbles so I doubt its headgasket, maybe thermostat. Water pump but im hoping its a easy fix. Please help.
  • 52,797 POSTS
Dont rule out a head gasket. From the overheating that may be the issue
i would change the thermostat first to see but get a leak down test to confirm no head gasket
BOCARD80
Im having a issue getting the two bolts off of the thermostat housing someone has stripped them and they are rusty so all attempts to take it off have been unsuccessful im not sure how im going to get these bolts off. Is a leak down test usually free?
  • 52,797 POSTS
No, runs about 80-100 bucks
roy
MADMIKE1735
  • 951 POSTS
Are the cooling fans working? Also, turn the heat on. Does it blow hot? If not, check the heater hoses going to firewall. If they are both cold, its likely your engine is airbound, and not allowing coolant to flow to your heatercore.
DANJOSCAK
  • 1997 SUBARU LEGACY
  • 4 CYL
  • AWD
  • 120,000 MILES
Sometimes the car overheats after driving 3-4 miles, other times after driving 12-15 miles it doesn't overheat at all. Once when it was hot, I took the bleeder plug out and steam was shooting 2 feet in the air, at the same time you could stick your finger in the coolant in the opposite side of the radiator. The dealer said the headgaskets were blown, the car ran w/o any misses/hesitation at low or high speed. Wouldn't bad headgaskets affect performance? Could the overheating be caused by something else? (Something less expensive to repair $1,900)
Thanks, Dan
  • 31,937 POSTS
You best get a cooling system test done to prove a faulty head gasket, this can be done with a simple chemical test of the gasses in the radiator. This will be conclusive. Do this first.
Mark (mhpautos)
74XR7
  • 18 POSTS
I would suggest that the thermostat is sticking shut sometimes. Aftermarket thermostats are mostly made in China and have spotty quality control, best to get the OEM replacement from a dealer (no, I don't work for a dealer or know anyone who does).
MISSKRIS
  • 1991 SUBARU LEGACY
Engine Cooling problem
1991 Subaru Legacy 4 cyl Front Wheel Drive Automatic
We have replaced the tstat timing belt waterpump and have flushed the system several times. But it still keeps overheating and pushing the water out of the overflow tank and this morning after sitting all night the system was still pressurized what can be causing this and can I fix this problem
LEGITIMATE007
  • 5,121 POSTS
The radiator can still be severly clogged. Also try changing the radiator cap if you havent already, otherwise the system will need to be pressure tested to help deterimine where the clog may be.
LEGITIMATE007
  • 5,121 POSTS
Before addressing any of the previous post. Check/change the engine coolant temp sensor, and make sure the radiator fan is coming on when it should, you will also need to hardwire the fan directly to the battery to make sure it is even any good.
