Pressing accelerator causes electrical short
AL514
  • 4,781 POSTS
If they can do diagnostic work, an oscilloscope is needed to check Alternator AC ripple.
You can explain the situation and see what they say. I only mention the Alternator because that and the battery can cause so many more problems than people realize. If there is low system voltage for one, then all the voltage in the whole car is going to be low. AC ripple destroys Automotive computers because they are designed for DC voltage only. I'm sure an Alternator shop does more than just charging systems.
What you can do is on your way to the shop, turn some things off, see if the clicking stops.
It should not cost much to replace a $15.00 relay: they just need to figure out which one it is. Going through the wiring diagrams I could probably tell you how many are under the dash, but they can take care of that. I'm assuming the reason it's happening more when you accelerate is the alternator is putting out more current, and this relay is warming up faster and the problem is presenting itself more. Unless it's a bad ground wire that's just vibrating more with the engine at higher RPMs, so 2 scenarios there. But i don't think and hope it doesn't cost you much at all.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-a-car-electrical-system-works
Monday, November 22nd, 2021 AT 7:33 PM
BBW54321
  • 17 POSTS
I am so glad I found you! Thank you so very much for all the time you spent helping me today! You have given me hope that this isn't the end, and I can manage (hopefully) the expense and go to the right place even having a clue I might know what's wrong, which is way better than usual. I don't mean to be religious, but may you be blessed! Also, I'm on permanent disability SSDI. However, in case I come into any money, do you have a link that accepts donations, because I'd sure like to give back when I'm able to, or nominate others to donate to you as a good cause, I can't thank you enough :) BBW54321
Monday, November 22nd, 2021 AT 7:56 PM
AL514
  • 4,781 POSTS
I appreciate the thought but save your money to fix your car. I'm a religious person too, so no worries. I do hope the fix is cheap for you, having to do diagnostics from such a distance like this is not always easy. I do mobile diagnostics here in my area (NC), but here we have to go by what the person tells us they hear or are experiencing. So, it can be difficult. But I do really appreciate the thought. Thats good enough for me. I hope it goes well and let us know what the actual issue was. We like a follow-up when possible. I just hope Im not too far off on my diagnoses. =)
Tuesday, November 23rd, 2021 AT 8:04 AM
BBW54321
  • 17 POSTS
Thanks very much again! So, it turns out that the strange noise was actually being made by a tab on the rear-view mirror! The shop didn't even charge me for the diagnosis, and I am extremely grateful! So, the very strange issue ended up not being something serious, and your terrific help brought goodness! May you remain wonderfully blessed and stay healthy please!
Monday, November 29th, 2021 AT 2:24 PM
AL514
  • 4,781 POSTS
A tab on the rear-view mirror huh. Well, that's a first for me. Sounded exactly like a relay from the video, but I'm glad they didn't charge you anything. It does get tough to diagnose things not being at the car. But I'm glad it worked out good for you. Have a nice evening.
Monday, November 29th, 2021 AT 2:53 PM
