Power windows not working
MELISSAA
My Car does not tell me where fuses are located I have no owners manual & there is nothing on cover but numbers & yes I have power mirrors problem started when dome lights would not turn off removed first bulb when removing second bulb all went out & windows stopped working I checked all of the fuses and they are okay so I replaced the GEM module and that worked thanks 2Carpros you guys are great.
Tuesday, January 26th, 2021 AT 11:40 AM (Merged)
JDL
  • 16,098 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
RICHARD PECK
  • 2003 FORD TAURUS
  • 3.0L
  • 6 CYL
  • 130,000 MILES
Windows will not operate. Work the drivers window rocker and only get a click.
HARRY P
  • 2,292 POSTS
Wait. Is it just the driver's window? Or is it all of the windows that are not working?
If it is just the driver's window that is failing, suspect a bad power window motor. It is receiving power (the click noise tells us that) but does not have the strength to push/pull the window up and down.
If it is all of the windows, suspect a bad fuse, switch, or circuit breaker.
