Power to vehicle
220,000 MILES • 4WD • AUTOMATIC
CRYSTAL COULTER
When taking off it has little power and builds up once you start moving, but not to it is normal speed. Also, it hits and misses like today, it is running fine but then it will hop in and it will do it again.
Feb 17, 2017 at 2:38 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first auto parts rent it. It can be a sensor problem or low fuel pressure see link.
when done get back to us with readings of fuel pump and if any codes.
Feb 17, 2017 at 4:11 AM
