My car will not start. It wants to start but will not kick over all the way. I have replaced the fuel pump and in line fuel filter, the fuel regulator, battery, starter, and nothing has changed in the smallest way it still sounds the same as it did before I started working on it. I have fuel pressure between 44 and 49 opened the air filter sprayed starting fluid into the side without the filter and it started, ran rough, but would only stay started if we continuously sprayed the starting fluid once we stopped the spray the engine shut off. not sure what to do. your help would be greatly appreciated. thank you
Aug 23, 2017 at 4:18 AM
