1991 Pontiac Transport altenator
1991 PONTIAC TRANSPORT
SWEETANGELBABY0587
Transmission problem
1991 Pontiac Transport 6 cyl Two Wheel Drive Automatic
how do i remove an alternater. we have taken off the power cords and removed the top bolt but cant get it out
Nov 9, 2008 at 5:33 AM
IMPALASS
  • 3,112 POSTS
Hello
When you say you can't get it out and you removed the top bolt. If I understand you correctly, did you remove the other bolts as well? Or, have removed all bolts but can not remove it from the vehicle because something is blocking it.
Nov 9, 2008 at 6:07 AM
