1998 Pontiac Sunfire Blower problems
150,000 MILES • 4 CYL • FWD • AUTOMATIC
NARCSISUSS
  • 9 POSTS
The blower is no longer forcing air through the vents. I checked the fuse in the drivers door panel (htr/blr?) and replaced the relay under the hood. I used a voltage tester to see if the blower was getting juice, and it wasen't; then checked if the leads going to the resistor where getting anything by setting the fan dial to different speed and putting the voltage prongs to ground and each wire individually, with no luck.
Does this mean the switch is bad (in the control panel in the dash)?
The a/c hasn't worked in a year, but tthe heateer hhas bbeen finne
Oct 14, 2009 at 3:26 PM
  • 75,988 POSTS
Hi there narcsisuss and TY for the donation this is what keeps the site going.
Okay-find the blower motor relay remove the relay there's gonna be 4 wires on the relay socket -brown, orange, black and purple if this is correct I want you to jumper the brown to the orange wire this will power the blower motor resistor bypassing the blower motor relay and blower motor should come on at every setting of the blower switch.
Note: before doing the above make sure the blower motor fuse 30amp in the engine compartment fuse/relay center is good. let me know we still got a long way to go if this don't work. Its gonna come down between the blower switch and the mode switch
Oct 14, 2009 at 6:58 PM
NARCSISUSS
  • 9 POSTS
Ok, when I jumpered the relay the blower kicked on. Sweet. I just replaced the relay, so does it mean I got a bad one or is there another cause?
Thanks
Oct 16, 2009 at 3:08 AM
  • 75,988 POSTS
Remove the blower motor relay and check for power on the brown wire while mode switch is at heater-do you have it
Oct 16, 2009 at 8:09 AM
NARCSISUSS
  • 9 POSTS
I removed the relay under the hood, couldn't tell which wires where brown; so just checked them all for voltage. When I'm standing on the driver side of the engine compartment the relay looks something like this:
|x---|-|----x
|X---------X
When I ground the black prong to the chassis, and stick the voltage meter on the lower left terminal the meter goes off the chart. All the other terminals don't show any voltage.
Oct 19, 2009 at 2:00 PM
  • 75,988 POSTS
Sir-you need to identify the wiring colors under the blower motor relay socket you probably have to remove the taping and insulation to identify the wires
Oct 19, 2009 at 2:04 PM
NARCSISUSS
  • 9 POSTS
Ok, took the relay block (?) off in the engine compartment. With heater on full; only found power on the ORANGE wire, the BROWN wire had no current.
Oct 21, 2009 at 7:54 AM
  • 75,988 POSTS
You should also have power on the brown wire not only on the orange while mode switch is on heat-Check the HVAC fuse 10amp if okay either you have a bad mode switch or the brown wire from the switch is open to the blower motor relay
Oct 21, 2009 at 8:49 AM
MRBOB459
  • 5 POSTS
This thread has been very helpful to me so far, but it ended before my problem was found. My car is a 1999 Sunfire with the same problem, but apparently a different cause. I always have the blower on, and while travelling this summer started smelling hot circuits. The next day the blower would not turn on. When I returned home I started by going to the junk yard and getting another blower because the odor I had smelled was very similar to that of burning fields; the replacement motor also did not work when installed. It was at this point I began doing diagnostics. Both motors work when attached to the battery, although the original motor does not turn as freely as the one I got from the junk yard.
Next I checked all the fuses in the system and replaced the blower motor relay. Still nothing. At this point I found this thread and completed all the diagnostics it recommended, hoping that Narcissus had the more serious problems because that is what I expected I have. I have power at the mode switch, which is one step beyond the diagnostics you detailed to Narcissus, but I have no idea where to go from here and I am not finding anything else on the internet about this problem. Can you help me go on from here?
Sep 28, 2016 at 10:52 AM
