2002 Pontiac Sunfire Mid Fan Speeds
JIMBO56
2002 Sunfire, the AC and heater fan will run on the low and high setting, but nothing in between. I'm guessing the fan switch shunts through different resistors for the different speeds, so possibly the switch needs replaced. Any ideas?
Thanks.
Jul 16, 2006 at 12:04 PM
MIKEYBDMAN
  • 623 POSTS
You need to replace the Blower Motor Resistor.
To replace this, remove the blower motor, then remove the resistor.
Be careful when installing the resistor screws. You only torque them to 9 inch pounds. Do not crack then new resistor.
Jul 16, 2006 at 1:24 PM
JIMBO56
Where is the blower motor located, and is the resistor mounted directly to it? Can you purchase a resistor at a parts store, or is this a dealer item?
Thanks.
Jul 20, 2006 at 12:50 PM
MIKEYBDMAN
  • 623 POSTS
I believe you can obtain the resistor from a regular parts store, but not 100% sure. The resistors are usually located in the air stream of the ducting. When you remove the motor, it will look like a small block wir a plug attached. The place these in the air path to keep them cool since resistors this big heat up when you use them.
Jul 21, 2006 at 7:39 AM
Suggested Repair
Replace the blower motor resistor. Remove the blower motor to access the resistor, a small block with a plug located in the duct airflow. Torque the resistor screws only to 9 inch-pounds so the new part is not cracked. It is likely available at a parts store.
Conversation Summary
The owner of a 2002 Pontiac Sunfire reports that the heater and AC blower runs on low and high but not on the speeds in between, and suspects the fan switch or resistors. The expert recommends replacing the blower motor resistor, which is reached by removing the blower motor and sits in the duct air stream to stay cool. The resistor screws should be torqued only to 9 inch-pounds. Parts-store availability is likely but not confirmed.
