2000 Pontiac Sunfire Water Leak
SIREXILON
Sombody told me that after 100.000 miles sunfire's needed to have the cylinder head ADjusted again.
Now problem is I don't know how much torwue I should applay to it.
Can you help me with that?
Apr 9, 2006 at 3:41 PM
LOSONE
  • 1,616 POSTS
The problem is probably a blown head gasket or a cracked head. They are prone to that condition. Re-torquing is not the solution. I think that engine is made in Agentina
Apr 10, 2006 at 11:10 AM
Suggested Repair
Do not re-torque the cylinder head. Inspect for a blown head gasket or a cracked cylinder head, which these engines are prone to.
Conversation Summary
The owner of a 2000 Sunfire asked for cylinder head re-torque specs after being told the head should be adjusted again after 100,000 miles, in connection with a water leak not coming from the pump. The expert said re-torquing is not the solution and that a blown head gasket or cracked head is the more likely cause.
