1990 Pontiac Sunbird Coolant Leak
JONLOVE
I have a 1990 Pontiac Sunbird conv w/ 2.0L engine and 128000 miles. When the engine gets to full temperature (1/2 way up the gauge and fan is on) it leaks coolant out the bottom below the area of the water pump, one might even say gushes coolant out the bottom. When the engine is cool and up until the gauge reaches 1/4 the leak is non-existant or very slow. It seems that the fuller the coolant the faster the leak, after some of the coolant is gone the leak slows down, but will eventually leak enough to cause the engine to overheat. The leak appears to be coming from the area of the water pump or the two hoses that connect to the engine below the intake manifold and behind the power steering pump. I am looking to remove the Alternator and Power steering pump in hopes of replacing those hoses. I checked a Chilton's manual and can not find any information on replacing those hoses. How big a job is this for an amateur mechanic? How much more teardown is required to access the Water pump? I am wondering if i should just tear down and replace the water pump and the hoses together. Would a cracked block tend to leak more when the engine was cool vs hot? :?
Sep 4, 2007 at 5:38 AM
MERLIN2021
  • 17,250 POSTS
Time to replace the waterpump! Water is now going around the pump bearing. Just a mater of time till you ruin the head or block if you keep driving!
Sep 4, 2007 at 11:05 AM
PIONEERLIVEDRIVE
I have a 1994 pontiac sunbird se 116,000 miles 3.1 v6
there is a small hose in the rear of the engine that goes to the heater core area in the dash compartment. It leaks... but my question really is, when i took the plastic tray off under the dash. The very hose that leaked led to a small tray in the plastic cover. It doesnt connect to anything. It just spills out into this tray. Which results in an interior leak and an exterior leak. Now I don't know if this is some kind of hot air hose that is some how taking on coolant. But it seemed kinda of odd that there was a hose leading from my engine to practically nowhere. So what i want to ask would I cause any adverse effects if I plugged this hose, and if so what they were? advice PLEASE?
Dec 1, 2007 at 3:55 AM
Suggested Repair
Replace the water pump. The expert says coolant is leaking past the pump bearing and continued driving can damage the head or block. Related hoses can be inspected if accessed, but the stated repair is water-pump replacement.
Conversation Summary
The owner of a 1990 Pontiac Sunbird with a 2.0L engine reported a coolant leak that became heavy once the engine reached operating temperature, appearing to come from the water pump area or nearby lower hoses. The leak slowed as the coolant level dropped but could eventually cause overheating. The owner asked how difficult it would be to access the hoses and water pump and whether a cracked block would leak more when cold. The expert advised replacing the water pump immediately, explaining that coolant was passing around the pump bearing and that continued driving could ruin the head or block. A later post about a different 1994 Sunbird heater-hose leak received no expert reply.
