1990 Pontiac Sunbird Drain Gas Tank Fix
RANDY SUTTON
how do you drain the gas tank on a 1990 sunbird?
Jun 5, 2006 at 7:18 AM
SYNCRAIT
  • 235 POSTS
the best way to drain any tank is to syphon it all out, you can buy one at the store pretty cheap, or if you like gas you can just take a hose and suck the end till gas comes out then drop the end in your hand so it is lower than the bottom of the gas tank and it will drain into your pail/whatever
Jun 5, 2006 at 7:40 AM
Suggested Repair
Siphon the fuel into a container using an inexpensive store-bought siphon, or a hose kept lower than the bottom of the tank.
Conversation Summary
The owner asked how to drain the gas tank on a 1990 Pontiac Sunbird. The expert recommended siphoning the fuel into a container with a store siphon or a hose held below the tank.
