If your car is automatic trans there is a sensor in the trasmision locate in the front of the trasnision that sensor is for the overdrive that work for a beter fuel economy, the sensor in your car may be damage you can unpludge the sensor, and your car will drive normally, and your car never going to turn off, I hope I help you with the problem.
SPONSORED LINKS
Sunday, June 1st, 2008 AT 2:01 AM
