Pontiac Window Motor Replacement Fix
PONTIAC
FURBY21
need help replacing car window motor. do I have to remove the window to get to the old motor? it has been released from the rivets and I dont know what all is holding it in place.
Thanks.
furby21
Feb 17, 2007 at 4:05 AM
CHEVY22
  • 1,375 POSTS
hi,
the window needs to be held up and released from the window regulator ,look close and you will see what i mean , two clips dealer parts are all one piece motor and regulator
jim
Feb 19, 2007 at 2:05 AM
Suggested Repair
Support the window glass in the up position and release it from the regulator at the two clips. Dealer replacement parts are typically a one-piece motor and regulator assembly.
Conversation Summary
The owner asked whether the window must be removed to replace a Pontiac window motor after the glass was released from the rivets. The expert said to hold the window up and release it from the regulator at two clips, and noted that dealer parts are a one-piece motor and regulator.
