2002 Pontiac Sunfire Side Mirror Replacement Fix
SAXMAN
Hello all, could anyone tell me how to replace a sideview mirror on a 2002 Pontiac Sunfire. I have had people tell me that you have to take the door apart, and I have had others tell me you do not. Could anyone help me out? thank you much.
Aug 16, 2007 at 3:22 PM
CLY
  • 308 POSTS
You just have to remove the trianguler trim piece on the door. I think it is held on by one screw. Then you will see the noise insulator. Just pull that out to revile the 3 bolts that hold the mirror on. remove those three nuts and pull the mirror out. You will have to disconnect the electrical plug if it has power mirrors. It shouldn't be to hard of a task...
Cly
Aug 16, 2007 at 11:17 PM
Suggested Repair
Remove the triangular door trim piece, typically held by one screw, and pull out the noise insulator to access the three mirror nuts. Remove the nuts, disconnect the electrical plug if the mirrors are powered, and pull the mirror out.
Conversation Summary
The owner asked how to replace the sideview mirror on a 2002 Pontiac Sunfire and whether the door must be taken apart. The expert said only the triangular trim and noise insulator need to be removed to reach the three mirror nuts, then the mirror can be unplugged if powered and pulled out.
