Pontiac Grand Am Window Crank Removal
BIGDAD0405
how do I take off window control handle for manual window.
Oct 11, 2007 at 2:10 PM
FAIRRACING31
  • 150 POSTS
I think you mean the crank handle, you can purches a inexpensive tool, or work a clean rag between the handle and door panel and pull on the rag to pop it out. There is a retaining clip that hold's the handle, you just pop it out.
Oct 12, 2007 at 5:10 AM
Suggested Repair
The manual window crank is held by a retaining clip. Buy an inexpensive clip tool, or work a clean rag between the handle and door panel and pull the rag to pop the clip and remove the handle.
Conversation Summary
The owner of a Pontiac Grand Am with a broken driver-front window asked how to remove the manual window control handle. The expert explained that the crank is held by a retaining clip, which can be popped off with an inexpensive tool or by pulling a clean rag worked between the handle and door panel.
