1995 Pontiac Grand Am No Start
CLINT D
1995 pontiac grand am 120k ,,,CAR WILL NOT START,TURNS OVER,NO POWER TO FUEL RELAY OR PUMP,AND RADIO QUIT WORKING AT SAME TIME ,, THINKIN IT IS A IGNITION SWITCH?? IF IT IS DO I NEED SPECIAL TOOLS?
Apr 5, 2006 at 7:28 AM
KENB79764
  • 52 POSTS
test fuses before looking at ignition switch. if fuses are good and you have power at the fuel pump relay fuse start checking wiring.
Apr 5, 2006 at 12:16 PM
CLINT D
[quote:c2d5995544="kenb79764"]test fuses before looking at ignition switch. if fuses are good and you have power at the fuel pump relay fuse start checking wiring.[/quote:c2d5995544]//////thankyou ,, I just tried the ignition switch and it worked thankyou for you reply ..
Apr 5, 2006 at 2:30 PM
Suggested Repair
Check the fuses before replacing the ignition switch. If the fuses are good and the fuel-pump relay fuse has power, inspect the related wiring. The owner later reported that the ignition switch restored starting and radio power.
Conversation Summary
A 1995 Pontiac Grand Am cranked but would not start, with no power to the fuel relay or pump, and the radio failed at the same time. The owner suspected the ignition switch. An expert advised testing the fuses first and checking the wiring if the fuel-pump relay fuse had power. The owner later reported that the ignition switch fixed the problem.
