1999 Pontiac Montana Sliding Door Locks
jim
I did as you said to do. There is no sound at all coming from the door when I press the lock button.
The one door decided to start working on its own. :)
Paul
jim
Suggested Repair
Pull the sliding-door panels and check for power at both sides of each lock actuator with a test light while someone holds the lock button. If power is present but the locks do not move, replace the door lock actuators. Tapping an actuator may free it temporarily, but replacement is the lasting repair.
Conversation Summary
The owner of a 1999 Pontiac Transport/Montana reported that both sliding-door locks did not respond to the remote or door lock buttons. The expert suggested listening for the actuators and, if they click without moving, replacing them. The owner heard no sound, and one door later began working on its own. The expert then advised checking for power at the actuators and noted that tapping them can temporarily restore operation before replacement.
