2000 Pontiac Montana Change Oil Light Reset
GMC
ELVISMARTE
I have a 2000 Pontiac Montana with 77,000 miles, i just changed the engine Oil and since i have changed it the change engine oil light has appeared. How can i reset the change engine oil light?
Mar 22, 2006 at 5:41 AM
  • 55,649 POSTS
With the engine off, key on, hit the thottle to the floor 5 times. Shut key off than turn back on, the light should be out.
Mar 22, 2006 at 7:59 AM
94IMPALASS
  • 12 POSTS
I have a 94 impala SS, and after you change the oil you have to go inside of the fuse panel in the passenger compartment on the drivers side. Turn the ingintion to the on position(dont start engine) then go inside the fuse panel there is a button that says(oil reset). Im pretty sure GM would have put this on most of there models,not exactly sure if your model does.
Mar 22, 2006 at 8:58 AM
  • 55,649 POSTS
Yes GM did do there service light reminder reset procedure a couple different ways, but your Montana is done the way I described earlier. :D
Mar 22, 2006 at 10:22 AM
Suggested Repair
With the engine off and the ignition on, press the accelerator pedal fully to the floor five times. Turn the key off, then back on. The change engine oil light should go out.
Conversation Summary
The owner of a 2000 Pontiac Montana with 77,000 miles changed the engine oil, after which the change engine oil light came on, and asked how to reset it. An expert said to turn the key on with the engine off, press the throttle to the floor five times, then turn the key off and back on. Another user described a driver-side fuse-panel oil-reset button used on a 1994 Impala SS, but the expert confirmed that the Montana uses the throttle procedure.
