1992 Pontiac Lemans -- poor brakes
1992 PONTIAC LEMANS
SQUASHTOWNER
Customer complained about poor brake pedal. Exact symptoms of a bad master cylinder. Replaced the cylinder, bled the brakes at each corner, and at all the ports on the master cylinder, and when not running, the car has PERFECT pedal...better than that of my 2005 matrix. Start the car, and the pedal goes to the floor when you push it, and the car will hardly stop.
We suspected a faulty reman MS (it happens) and replaced it, and did the whole bleeding process again. Same pedal.
Car has new pads, rotors, and recent rear shoes. Rear brakes are adjusted, caliper slides are perfect, wheel cylinders move freely.
Is this the booster? Or could it be those 2 little proportioning valves on the brake lines, attached to the MS?
Thanks for any help!
Feb 6, 2006 at 8:27 AM
CHEVY350GUY
  • 109 POSTS
no abs?
Feb 6, 2006 at 9:11 AM
SQUASHTOWNER
No ABS.
Feb 6, 2006 at 9:51 AM
MVANNESSJR
  • 223 POSTS
Check the vacuum lines and make sure they look good. Is there a hissing sound? I would suspect a possible failing power brake booster. There isn't much left if you've already replaced the master cylinder.
Feb 6, 2006 at 7:37 PM
SQUASHTOWNER
[quote:664159f9a7="mvannessjr"]Check the vacuum lines and make sure they look good. Is there a hissing sound? I would suspect a possible failing power brake booster. There isn't much left if you've already replaced the master cylinder.[/quote:664159f9a7]With the booster vacuum line plugged in, or disconnected, there's a very noticeable"SSsshhhhtttt" sound every time you pump the brake pedal.
Feb 6, 2006 at 8:49 PM
SQUASHTOWNER
Oh, and those little proportioning valves re unavailable anywhere, apparently. Our local GM dealership has onle ever had one Lemans in for work in all the time they were sold, and they told us that the car is now classed as "vintage" and parts are hard to come by, if not impossible.
Feb 6, 2006 at 8:51 PM
MVANNESSJR
  • 223 POSTS
Without actually being there and listening to it myself, it would appear that the power break booster has seen better days and should be replaced.
Feb 7, 2006 at 12:04 AM
