1967 Pontiac Lemans
1967 PONTIAC LEMANS
LEMANS
I have a 1967 Pontiac LeMans with a 326 engine and a Rochester 2GC carb. Th e engine floods because the carb float sticks. The carb has been rebuilt 3 times: once by my Pontiac dealer, and I have replaced the float. The only thing that seems to work is to rap on the fuel filter with the handle of a screw driver. :( Any ideas?
Mar 31, 2006 at 9:21 AM
LOSONE
  • 1,616 POSTS
That carb may have a plastic block that fits over the float chamber--it might be binding. If it has a metal float look for shiny places on the float where it has beeen rubbing. Sometimes the needle is missing the small clip to hold it on the float.
Wish I had it on my bench--I could fix it blindfolded.
Mar 31, 2006 at 9:40 AM
LEMANS
[quote:212b37395a="losone"]That carb may have a plastic block that fits over the float chamber--it might be binding. If it has a metal float look for shiny places on the float where it has beeen rubbing. Sometimes the needle is missing the small clip to hold it on the float.
Wish I had it on my bench--I could fix it blindfolded.[/quote:212b37395a]
[quote:212b37395a="lemans"]
Thanks for the help, funny thing about it, it only happens if the car sits for about 5 days or more. I don't really trust the plastic one so I am going to get a brass one and give that a shot. - Thanks[/quote:212b37395a]
Apr 1, 2006 at 10:48 PM
IMNOTLOKIN
  • 11 POSTS
Have the same car to this day. Back in the late 70's I found the same problem with the plastic float cover. My car, at the time, needle was sticking in the plastic. I used a small drill bit to open the hole very slighty. The pin should move freely in the hole. I think this card also has a rubber washer and rod on top? Make sure it seals the vent off. This work for me.
Nov 14, 2007 at 10:29 AM
