Customer complained about poor brake pedal. Exact symptoms of a bad master cylinder. Replaced the cylinder, bled the brakes at each corner, and at all the ports on the master cylinder, and when not running, the car has PERFECT pedal...better than that of my 2005 matrix. Start the car, and the pedal goes to the floor when you push it, and the car will hardly stop.
We suspected a faulty reman MS (it happens) and replaced it, and did the whole bleeding process again. Same pedal.
Car has new pads, rotors, and recent rear shoes. Rear brakes are adjusted, caliper slides are perfect, wheel cylinders move freely.
Is this the booster? Or could it be those 2 little proportioning valves on the brake lines, attached to the MS?
Thanks for any help!
Feb 6, 2006 at 8:27 AM
