2006 Pontiac Grand Prix Sidewall Screw Fix
ROBIN45
2006 pontiac grand prix
I have a screw lodged in the sidewall of my tire you think it will cause the tire to go flat? :roll: :roll:
Apr 14, 2007 at 5:05 AM
LSUSSEL
  • 252 POSTS
Yes, deff..
replace the tire, I would suggest for you to have it patched but most leaks in the sidewal cant be patched and it wont go flat right away but it will slowy lose air.. replace the tire!
Apr 20, 2007 at 3:58 PM
Suggested Repair
Replace the tire. A screw in the sidewall will cause a slow air leak, and sidewall punctures generally cannot be patched.
Conversation Summary
The owner of a 2006 Pontiac Grand Prix asked whether a screw lodged in the tire sidewall would cause a flat. The expert said the tire would slowly lose air, that most sidewall leaks cannot be patched, and recommended replacing the tire.
