Where do I add transmission fluid? Do I add it where the dip stick is? It's a 3.1L v6 engine w/ multi port fuel injection.
Jan 24, 2007 at 4:46 AM
Add transmission fluid through the dipstick tube. With the engine warm and running and the transmission in park, wipe and reinsert the dipstick, then check the level. The marks are in pints, so add fluid slowly to avoid overfilling.
The owner of a 1993 Pontiac Grand Prix LE with a 3.1L V6 asked whether transmission fluid is added at the dipstick. The expert confirmed that it is and advised checking the level with the engine warm and running in park, then adding fluid slowly because the marks indicate pints.
