How do you remove the old battery from a 2001 Pontiac Grand Prix?
Apr 14, 2006 at 7:00 AM
Remove the support rod and plastic cover. Disconnect both battery cables with an 8mm (5/16) wrench, negative first, then lift the battery out carefully because the fit is tight.
The owner asked how to remove the battery from a 2001 Pontiac Grand Prix. The expert advised removing the support rod and plastic cover, disconnecting both cables with an 8mm wrench starting with the negative, and lifting the battery out while watching fingers because of the tight fit.
