1996 Pontiac Grand Prix P0172 Rich
Are you using a K&N air filter? An oiled filter can play hell with a MAF even when it is new.
Did you replace both the upstream O2 and the one after the cat? Any exhaust leaks?
Check for vacuum leaks @ the hoses and Map.
What fuel pressure did you get with the engine off? Does the pressure bleed down?
Does the pressure fluctuate with the engine running?
I'd bet on a fluctuating pressure regulator or a leaking injector. Try some injector cleaner or have them professionally cleaned. I like chevron with techron.
Good luck and let us know. :)
To: peppermrj
Posted: Sun Mar 18, 2007 2:08 pm
Subject: p0172
"Thanks for the input regarding my problem on this code.I found that there was a pinched return fuel line and the problem is now fixed. thank you again,Bill "
Thanxs for the update. :)
Suggested Repair
Inspect the fuel return line for a pinch or restriction. On this car, a pinched return line caused the rich condition and P0172; correcting it fixed the code. Also verify fuel pressure holds and does not fluctuate, and check for a faulty pressure regulator or leaking injector if the line is clear.
Conversation Summary
A 1996 Pontiac Grand Prix 3.1 with about 100,000 miles kept setting P0172 (system too rich, bank 1) despite a tune-up and replacement of the converter, oxygen sensors, MAF, MAP, throttle position sensor, idle air control, EGR, and gas cap. Fuel pressure tested good and the car ran well, but the code blocked inspection. Experts asked about OEM parts, a rich smell, an oiled air filter, both oxygen sensors, exhaust and vacuum leaks, and whether fuel pressure bled down or fluctuated, and suggested a pressure regulator or leaking injector. The owner later reported a pinched fuel return line was found and the problem was fixed.
