1994 Pontiac Grand Prix No Start Clicking
GPJAY
Pontiac Grand Prix 1994 131,000milles and its a 3.1 liter. I just got the car repaired today it was an intake gasket and now the car will not start. While driving I noticed that when i put the turn signal on the speedometer would jump and the speedometer would also jump when i applied the brake pedal. When i put the turn signal on also my radio would cut out and when i would step on the excelerator from a complete stop the car would struggle to move like there was no transmition in the car at all.The car was perfectly fine until i brought it into the repair shop. Now the car wont start when i turn the ignigition the car just makes a clicking souind and the lights on the intrument pannel blink with the clicking noise.I know it has to be something eletrical but i dont know what. Could someone please help me i really net this car to be driveable. i need it for school.
Aug 15, 2007 at 11:37 AM
CLY
  • 308 POSTS
With the gauges jumping around and the lights flickering I woulld suspect that maybe you have a loose ground or something. I would check and make sure that the battery cables are clean and tight. Also make sure the grounds on the engine block are tight. With the clicking while tring to start it sounds like a low battery. Make sure that they pluged the alternator wires back in. Have you taken it back to them yet to see if it is something that they may have over-looked?
Cly
Aug 15, 2007 at 10:42 PM
Suggested Repair
Check that the battery cables are clean and tight and that the engine-block grounds are secure. Confirm the alternator wiring was reconnected after the intake gasket repair, and return the car to the shop to recheck anything that may have been overlooked. The clicking and flickering point to a low battery or poor ground.
Conversation Summary
The owner of a 1994 Pontiac Grand Prix says the car had electrical symptoms before an intake gasket repair and now will not start, only clicking while the instrument lights blink. Earlier, the speedometer jumped with the turn signals and brakes, the radio cut out, and the car struggled to move from a stop. The expert suspects a loose ground or low battery and advises checking battery cables, engine grounds, and alternator connections, then taking the car back to the shop.
