2000 Pontiac Grand Prix LOSING SPARK
BLAKESFIRSTT
  • 2000 PONTIAC GRAND PRIX
Engine Mechanical problem
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic? Miles
Whether Im driving down the road or just at idle or even trying to start at times there will be no spark.I Am not sure what would intermediately cause that to happen. After a couple minuets of trying to start it will finally get spark back up n go. Any help would be greatly appreciated
Friday, February 12th, 2010 AT 8:34 AM
TOOOMANYTOYS
  • 513 POSTS
Check the connector going into the coil pack module. Best way to determine would be when its not starting to wiggle that connector. If it starts you may need to replace loose terminals in that connector
Friday, February 12th, 2010 AT 8:39 AM
BLAKESFIRSTT
  • 32 POSTS
Tyvm. Took it to dealer and found out there was a lose ground wire and one other wire that had come apart. And so far is running gr8 again.
Friday, February 12th, 2010 AT 6:26 PM
