2000 Pontiac Grand Prix Car won't start.
ALICIOUS
  • 2000 PONTIAC GRAND PRIX
put new fuel filter on trys to start but wont start
Wednesday, January 27th, 2010 AT 11:44 AM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, January 27th, 2010 AT 5:06 PM
