I was driving my 2000 grand prix and used the turn signal while tapping the brake. Suddenly, the car shuts off but the ravioli and heat was still on. There was no pier surge or anything. Everything else functioned as normal without skipping a beat. When I came to a complete stop, I put it into park and tried to remove the key. It wouldn't come out or and I couldn't shift out of park. Also, when I turned the key forward to try to start the car, nothing happened at all. It was if I never turn the key in the first place. So I popped the hood and took the ignition fuse out of "maxi 5" and it blew out. Every fuse I put in, no matter how strong, did the same thing. Since I know very little about cars, I'm turning to you for an answer as to what can the problem be?
May 20, 2015 at 12:26 PM
