HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Prix
Exhaust
White Smoke
1999 Pontiac Grand Prix
JORDANT46124
MEMBER
1999 PONTIAC GRAND PRIX
V8
2WD
AUTOMATIC
117,000 MILES
Knocking sound coming from engine with white smoke out the exhaust
Tuesday, August 3rd, 2010 AT 7:17 PM
MMPRINCE4000
MECHANIC
Not good, this would indicate a headgasket problem and damaged main/cam bearings.
Perform a compression test to check headgasket, but if you have a knock, the bearings are damaged.
SPONSORED LINKS
Saturday, August 7th, 2010 AT 8:13 AM
Please
login
or
register
to post a reply.
Related White Smoke Content
Why Is White Smoke Coming Out Of Exhaust
Asked by
DURAN81
1 ANSWER
1999
PONTIAC GRAND PRIX
GUIDE
White Smoke
There are different levels of white smoke/steam which could be a normal occurrence. A small amount of water is produced as a normal bi product of the combustion process and...
White Smoke Right After Startup But Goes Away
1999 Grand Prix Gt Not A S.C. 106,000 Miles. Just Replaced Upper Intake Plenum With Gaskets And New Pcv Plus Cleaned Throttle Body And...
Asked by
tscheer771
PONTIAC GRAND PRIX
1998 Pontiac Grand Prix White Smoke
I Have A 98 Grand Prix Gt V6 3.8 With 176000. My Cars Engine Caught On Fire Due To A Oil Leaking Into A Spark Plug. Since It Has Been At The...
Asked by
badassnat
1998
PONTIAC GRAND PRIX
White Smoke Coming Out Of Mufflers
I Have A 1999 Pontiac Grand Prix With 98,000. I Have White Smoke Coming From The Mufflers, And A Code Reading Of 201. I Replace The Fuel...
Asked by
superman
1 ANSWER
PONTIAC GRAND PRIX
2001 Grand Prix - Low Coolant Light And White Smoke
I Have A 2001 Pontiac Grand Prix Gtp (supercharged) With About 85000 Miles. About 2 Months Ago I Had The Low Coolant Light Come On And So I...
Asked by
Mr.Anderson
1 ANSWER
2001
PONTIAC GRAND PRIX
VIEW MORE
SPONSORED LINKS
Exhaust System Removal
Catalytic Converter Replacement
Lean Exhaust
Online car repair manuals
