White smoke is just coolant burning off. If it's not coming out the tailpipe, then it's not as major an issue as it could be.
You obviously have coolant leaking from somewhere under there. If you're getting all that white smoke, it shouldn't be too tough to locate it. Keep in mind that the source of the leak might be above where the smoke starts, as it may leak/drip down onto the hot engine block, then burn off. Start the car and hold the throttle open some from under the hood, and watch for where it starts leaking. Given there's already a significant leak, I'd wear protective gear, especially safety goggles in case a hose bursts or something. Check all the coolant hoses, connections to the radiator, water pump, and thermostat (this might be the "temperature sending unit"). As the car warms up, the problem should occur again, and if you watch it happen, it shouldn't be hard to notice where the leak is coming from.
Friday, March 31st, 2006 AT 11:04 AM
