2003 Pontiac Grand Am Car panel and lights turn on but engi
2003 PONTIAC GRAND AM
MY1VETT
Electrical problem
2003 Pontiac Grand Am 6 cyl Automatic
I have a pontaic Grand AM 2003. I was out cleaning the car and had the key in the ignition in the on possition. It was only on with the radio on for 15min before it just shut off. I took the key out of the ignition put it back in and tried to start the car but it wouldn't. I hooked up battery cables and tried to jump the car. All of the acessory's turn on, as well as the radio, air, heat, everything. I try to start it but it won't even crank over. I tested the battery and it's fine. It seems that there is no power getting to the relay starter switch. Can anybody help fix this please?
Apr 25, 2009 at 10:58 AM
MMPRINCE4000
  • 8,548 POSTS
Check ign. fuse. Never leave ign. in "on" for extended periods of time, use "assy" if you want to listen to radio.
Apr 25, 2009 at 11:41 PM
MY1VETT
I checked the fuse and it seems to be fine. I also checked the relay starter switch and that was fine. Any other suggestions would be helpful. Thank you
Apr 26, 2009 at 3:44 PM
MMPRINCE4000
  • 8,548 POSTS
Are you getting a "click" when you turn to start?
If not, check for 12V at solenoid on starter (car on jacks) ign. to start. if nothing, then (assuming relay and fuses are OK) the ign. switch itself.
Apr 26, 2009 at 10:14 PM
MY1VETT
Thanks for your help. It was the ignition switch.
Apr 27, 2009 at 11:54 AM
MMPRINCE4000
  • 8,548 POSTS
Thaks for using 2carpros.
Apr 28, 2009 at 12:01 AM
