2002 Pontiac Grand Am crusie control
2002 PONTIAC GRAND AM
115,000 MILES • 4 CYL • FWD • AUTOMATIC
JASONSWIFE84
i just bought my 2002 pontiac grand am and when i push the on/off button on steering wheel the light comes on on the button but when i hit set nothing happens and the "cruise" light on the cluster doesnt light up and the cruise doesnt work,, what could the problem be?
Feb 12, 2008 at 2:24 PM
KAYEROBINSON1
  • 11 POSTS
The switch needs to be replaced. make sure and check the fuses for the cruise control too. they are located under the fuse panel on the passenger side of the car, open the passenger door and you will see it , it has a grey cover , it is on the side of the dash facing the passenger door. there will be 3 or 4 fuses for the cruise control, if you have the owners manual it lists which fuses are for the cruise control.
Feb 29, 2008 at 1:38 PM
