2001 Pontiac Grand Am security light
PATEARLLEY
  • 2001 PONTIAC GRAND AM
Electrical problem
2001 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 139.00 miles
the security light keeps coming on is there a fix for it. Will it hurt if I keep driving it
Tuesday, February 24th, 2009 AT 8:51 AM
  • 109,885 POSTS
Hi:
Chances are the key you are using needs replaced because the chip in it is no longer working properly. Try a different key to see if that helps. Also, if it doesn't, you may need to contact a dealer to have it scanned. They have the proper test equipment. Finally, if the light is always, at some point the security system may make the car not start.
Wednesday, February 25th, 2009 AT 10:33 AM
