1999 Pontiac Grand Am Ignition/security light
DC1152
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • 18,000 MILES
Occationaly I will attempt to start the care and the engine will crank, but will not turn over. The security light will come on, I then wait and in approx. 10 min. The car will start. Recently this is happening on a more frequent basis. Considering the model, year and mileage which component is the culprit: The Ignition switch or the key cylinder and sensor? How would I test both? What would you try first?
FYI
This problem has happend with 3 differant ignition keys. Also, sometimes the security light will come on when the car is started and will remain on for the whole trip. The next day the car starts fine and the security light is off.
Wednesday, November 11th, 2009 AT 8:06 PM
  • 109,885 POSTS
If it happens with three different keys, chances are the problem is in the steering column or the computer itself. Here is the tricky part. The only place that has the proper test equipment to test it is a dealer. I hate to say it, but you need to take it to a dealer to have the problem diagnosed.
I wish I had a better answer for you, but that is the bottom line.
Thursday, November 12th, 2009 AT 7:57 PM
