1997 Pontiac Grand Am compressor makes noise
80,000 MILES • 4 CYL • FWD • MANUAL
NUMLAUF
hello,
my a/c compressor makes a scratchy sound even with the ac turned off. the a/c also dosn't work when turned on either. i am worried that the ac will soon lock up, break the belt, and leave me without a charging battery.
to avoid this i have been spraying the clutch with pb blaster( basically WD40). the noise will go away for a few days and ill have to spray it again. i noticed the whole pulley for the ac spins when it makes the scratchy sound and after i spray it only like half of the compressor pulley spins and the noise goes away(im assuming the clutch).
the ac bypass is a whopping 70$ i am a poor collage student and wont be able to buy a new compressor or ac bypass for a while or find the time to change it with all my studies and work.
my question is if i continue to spray the pb blaster on the clutch of the ac compressor pulley will my pulley soon lock up? or will i be able to get a lot more life out of the pulley?
thanks a lot, nick
Aug 18, 2010 at 2:11 AM
  • 110,248 POSTS
Nick:
Honestly, I can't tell you how long it will last. I assume the PB blaster is lubericating around the clutch and stopping the sound. Are you sure the product isn't getting on the belt and stoping the sound. If you have a dry belt, spraying it with a product like mentioned will quiet it down for a short period of time.
Aug 19, 2010 at 2:22 PM
NUMLAUF
the belt is fine i just changed it like 2 weeks ago
Aug 21, 2010 at 1:05 AM
  • 110,248 POSTS
I hate to say it, but I honestly can't say how long it will last.
Aug 21, 2010 at 1:53 PM
