1997 Pontiac Grand Am HELP A/C Compressor wont stay on
1997 PONTIAC GRAND AM
177,000 MILES • 4 CYL • FWD • AUTOMATIC
LAOUIDA
Hubby changed compressor on car, since then it keeps throwing the belt off. Pulleys have been checked, brackets, and everything else close to it has been checked. When the car starts the a/c compressor kicks (unit) out about 2 inchs and then belt comes off. Hubby has retapped and placed better grade of bolt in, but still breaks the bolts.
Is there something we are missing?
Apr 16, 2009 at 10:31 AM
BUDDYCRAIGG
  • 2,262 POSTS
from what i'm reading, the compressor is locked up.
try turning the hub (not the outer pulley the belt rides on) of the compressor by hand
Apr 16, 2009 at 2:09 PM
LAOUIDA
The compressor is not locked up, the a/c works just fine. But after awhile the rear bolt is sheared into. Thats when the compressor turns cockeyed (not straight).
Apr 16, 2009 at 2:12 PM
BUDDYCRAIGG
  • 2,262 POSTS
something major has to be going on for it to break a bolt.
what about too much oil in the system? when the excess oil hits the compressor, it hydrolocks and seizes the pulley. (i'm grasping right now)
If the belt runs true and stays on while the compressor is not engaged, then it has to be something going on INSIDE the compressor.
EDIT: i wanted to ad that i've had 2 compressors in a row be bad from a very expensive auto part store (i dont want to say any names)
but it can happen.
Apr 16, 2009 at 3:46 PM
