Hello, do some of the basic tests, have a helper crank it, while you have spark at the plugs and injector pulse. Go from there.
To check if the computer is awake, you can check for ref voltage at one of the engine sensors, like the tps, key on, you don't have to crank it. If nothing there, you may have to check some of the feed circuits.
SPONSORED LINKS
Thursday, March 26th, 2009 AT 11:19 AM
