There is a flasher for the hazard and a flasher for the signals as well. Hazard flasher is located in front seating area, driver side, under dash, above kick panel, mounted in bottom of convenience panel. Turn signal flasher is located in front seating area, driver side, under dash, driver side of steering column, mounted on support bracket. Also inspect relays as well. Relays will be found underhood, in engine bay.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Wednesday, February 4th, 2009 AT 12:09 AM
