1996 Pontiac Firebird Gas Cap Pressure
JASONR015
1996 Firebird 3.8L V6. I have a problem with air pressure building under the gas cap which really decreases the power. When I loosen the gas cap the air hisses out and the power is back. Thank you.
Jun 3, 2007 at 9:50 AM
SERVICE WRITER
  • 9,123 POSTS
Are there any codes in the computer?
Sounds like an evaporative cannister purge solenoid problem, not allowing vapors to be purged.
Jun 3, 2007 at 11:58 AM
JASONR015
Nope, no codes.
Jun 3, 2007 at 2:04 PM
TBDK
  • 24 POSTS
The problem could be as easy as your gas cap. The gas cap has or is supposed to have vents that allow air to enter the tank as gas is pumped into your motor. If your cap doesn't have vent or they have some how become clogged(I have no idea how) then the air would be able to enter the tank. I would try with the obvious. If you have another car, swap the gas caps for a bit and try it out. If you don't, you may have to pony up the cash for a cap. ranging from $10 to $30 depending on the type you want(lock, no lock, brand name, etc......)
Good luck fixing your problem.
Jun 5, 2007 at 6:11 PM
Suggested Repair
Inspect the evaporative emissions canister purge solenoid, which may not be purging tank vapors and can cause pressure under the gas cap and reduced power. No diagnostic codes were present.
Conversation Summary
A 1996 Pontiac Firebird 3.8L V6 builds pressure under the gas cap and loses power until the cap is loosened and the pressure hisses out. No trouble codes are stored. An expert suggested a faulty evaporative canister purge solenoid that is not purging vapors. Another reply suggested testing or replacing the gas cap in case its vents are clogged.
