1991 Pontiac Firebird Oil Pan Leak Fix
DRAGO86
i have a 1991 Firebird 3.1L Auto I just recently scraped the bottom of the car on the highway and now its leaking motor oil it looks like the bolt looks really bad and it has a little hole under it where most of the oil is leaking. i was wondering whats the cheapest way to get it fixed or is there anything i can do to keep it from leaking
thanks
Dec 14, 2006 at 3:13 AM
CARUNDELL
  • 602 POSTS
[quote:94f0bc110d="drago86"]i have a 1991 Firebird 3.1L Auto I just recently scraped the bottom of the car on the highway and now its leaking motor oil it looks like the bolt looks really bad and it has a little hole under it where most of the oil is leaking. i was wondering whats the cheapest way to get it fixed or is there anything i can do to keep it from leaking
thanks[/quote:94f0bc110d]
Hey drago,
Got to recommend an oil pan replacement! You don't want that puppy goin' dry!
Chris
Dec 14, 2006 at 3:17 AM
Suggested Repair
Replace the damaged oil pan. Do not keep driving with the leak, or the engine may run dry.
Conversation Summary
The owner of a 1991 Pontiac Firebird 3.1L automatic scraped the underside on the highway and now has an oil leak near a damaged bolt and a small hole. The expert recommends replacing the oil pan and not letting the engine run out of oil.
