1997 Pontiac Firebird Fuel Gauge Stuck
TRACKER
1997 pontiac firebird 6 cyl...76,000..fuel gauge won't work..replaced fuel sending unit and gauges..is there anything else to check...PLEASE HELP
Jan 10, 2007 at 8:23 AM
2CARPRO JACK
  • 11,533 POSTS
At the bottom of the main forum page is a link to Mitchell1. Go to wiring diagrams and find th esender wire. Test with an Ohm meter for continuity, there might be a break in the wire
Jan 10, 2007 at 11:27 PM
SERVICE WRITER
  • 9,123 POSTS
Does it always read empty?
Or always read full?
Jan 12, 2007 at 12:35 PM
TRACKER
it always reads 3/4 except when you fill it then it moves toward full a little bit
Jan 14, 2007 at 5:20 AM
SERVICE WRITER
  • 9,123 POSTS
I'm far from a wiring pro, and Jack probably has the right answer, but I have received bad sending units that did that.
Jan 14, 2007 at 5:47 AM
Suggested Repair
Using the wiring diagram, test the fuel sender wire with an ohmmeter for continuity and repair any break. A defective replacement sending unit can also cause the gauge to stay near 3/4 and move only slightly when filled.
Conversation Summary
A 1997 Pontiac Firebird fuel gauge still does not work after the sending unit and gauges were replaced. It stays near 3/4 and moves only slightly toward full when the tank is filled. Experts recommend checking the sender wire for continuity and note that a bad replacement sending unit can cause the same symptom.
