1995 Pontiac Firebird Coolant Leak
Just helping here, leaking around the spark plug-Try removing the plugs out and cranking it over for 10secs you see coolant coming out that confirms SW suspicions.
Also when engine is hot-does it cranks over easily-if not than could be hydrolocked-in by water in the combustion chamber.
Sounds like the escort lol huh SW. Good day my friend.
What Escort? :wink:
Suggested Repair
Exhaust gas in the coolant points most likely to a failed head gasket, with a damaged cylinder head possible and a cracked block less likely. Remove the spark plugs and crank the engine briefly to check for coolant in the cylinders. Do not delay, because coolant in a cylinder can hydrolock and damage the engine.
Conversation Summary
A 1995 Pontiac Firebird Trans Am leaks coolant only when shut off, near the spark-plug area above the crank pulley, without overheating, smoke, or milky oil. A test reportedly found exhaust gas in the cooling system. Experts said this indicates a bad head gasket and possibly a damaged head, with a cracked block unlikely. They advised removing the plugs and cranking briefly to look for coolant, warning that hydrolock could ruin the engine. The owner said it still starts easily when hot.
