Usually when a waterpump fails the seal goes bad and you see coolant leaking out the "weep hole".
Having said that, it was ever replaced with a WP with a plastic impeller, the plastic can seperate from the shaft causing little or not coolant movement.
You can take the radiator cap off and start the engine, wait until the thermostat opens and look at the coolant, it should start moving through the radiator, if it doesn't the pump is bad.
You can also have a coolant pressure test to rule out a cracked head or head gasket.
Jul 4, 2007 at 12:06 AM
